Re: 1986 Mercury 175hp Black max - RPM Question?
Coupla things. If you have an XR2, then the high five prop that fits would be even pitches, with 24 being the steepest. If it's a standard 4 3/4 inch LU then the pitches would odd, and I think 25 is the steepest. I suspect you have the large LU and a 25 pitch.
I have an 88 Tracker with an XR4 and a 24 pitch high five on it. It runs in the low 60's when light at about 6200 rpm, and loaded right at 60 at 5900 rpm. When I'm towing a water skier, or camping, family low throttle stuff, I put on a 22 inch high five. If I find a cheap one, I'll go to a 20. If I shaved the heads and upped the compression a little bit, and threw out the trolling motor batteries, 70 would be easily achievable.
5000 rpm at WOT will beat that engine to death. It needs to run at 5500, and 6000 won't hurt it. 6500 is about the limit for the VRO oil injection system.
Top performance is achieved by running the engine set back 6 inches and high enough so the prop is surfacing. Mine is high enough so that I have to watch the water pressure. It is set so that just before I lose water pressure, the engine is trimmed about level with the lake, and throws a roost that's only a few feet high. The prop is surfacing about 2 inches at that point. That gives me both best speed and drivability at speed.
When I bought my boat, I gained almost 5 mph just by going through the engine and carefully detailing all adjustments, mostly float level and timing.
I find that with the high five, I can get enough bite to launch like a slingshot, and still run it surfacing. A 4 1/4 inch LU usually will fail when surfacing a 3 blade prop, but seems to stand up fine with a 5 blade. Stands to reason as the tortional vibration would be less, and that's the killer. With a 3 blade, I'd have to run deeper, and would not gain any top end and would lose hole shot.
I ramble a lot
hope it helps
John
