i've developed a slight hesitation on my 3.0L I/O Mercruiser in my pontoon boat.  at pretty much any throttle over 3K it will "hesitate" for a second and then proceed.  It's like you pull the throttle back and quickly push it back forward.  It happened a few times on the lake today and then it got harder to replicate.  From reading the manual and the service manual, it sounds like i need to get into the fuel/water separator and the filter.  My first question is: are there any tricks to getting it off?  last thing i want is to drop a bunch of small parts in the bilge.  mine doesn't have a real screw on filter, it's got the one that is built into the fuel pump.  its an '05 carberated model.  the service manual wasn't real clear on how to get into it.  does it have to come out completely, or can you drain the water and check the filter while mounted to the motor?
thanks for the help, and any suggestions would be appreciated.
