Converting from VRO to premix
spingley
I have a 1986 Johnson 90 OB that has a bad fuel/VRO pump, would like to convert to premix, does anyone know what fuel pump would fit that I could order from iboats?
Fl_Richard
Re: Converting from VRO to premix
If the fuel pump part works and the oil side doesnt you can just disconnect the oil side and premix. Detailed instructions are on this board. Search for disconnect VRO.
Boss Hawg
Thats what i did to my '87 70hp & never looked back ;)
tashasdaddy
Vro Replacement Fuel Pump Kit "no Oil"
(for Using Oil/gas Pre-mix In Fuel Tank)
#5007422 it is in the $300 range.
$100 range
Part Number: 0385784
Description: FUEL PUMP AY
Pack Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0395712,0398385,0433390,0438559
spingley
Thanks for everyone's help, I have a replacement pump on order.
CharlieB
Some VRO's have rebuild kits available, depending upon model.
I'm such a cheap s.o.b. that I would seriously consider rebuilding the airmotor side of that pump for far less than what another pump assy costs.
spingley
I purchased a new standard fuel pump for less than half price of a VRO rebuild kit. So I went with that especially considering that the original pump would still have 23 year old parts on the oil side as the rebuild kits only contain gas side parts.
kenmyfam
Good choice. New pump should be a known quantity !!!
tashasdaddy
mbueker, you need to start a new post so your question does not get confused with the original poster's.
d.boat
$100 range
Pack Qty: 1
Weight: 0.44 lbs
I tried to find VRO/OMS replacement pumps (BRP items) on iboats, but couldn't. Only Sierra and aftermarket things. I'm trying to find a BRP 50047423 (VRO/OMS for three wire). If they're on the iboats site, I'd like to patronize the company!
spingley
iboats does not carry them, if you Google VRO pump you will find a couple sites that carry them.
