hello.i just bought a 1977 johnson 115 and it has fire but wont start.i tried spraying starter fluid in the carbs and the spark plug holes but nothing happened.i pulled the flywheel and the key is ok.when i put the flywheel back on it started and ran a couple seconds and died.then it was back to just spinning over so i pulled the flywheel again and put it back on then it backfired.i checked the key and it was sil ok.the guy i bought it from said it was running when he took it of the boat 8 months ago.the only problem he had was a miss that would comeand go.he thought it might need a coil.could someone please help im ready to blow it up. thanks
