Re: 93 merc 90 HP/3cyl. reed inspection
sschefer
You are exactly correct on your description of the reed block assembly, 9 petals per block. I noticed the bolts were not very tight at all when I loosened them. Also you are correct in the way the gaskets came off. They came off easy with only the gaskets sticking a little around two bolts. The petals all lay flat except one, however it still is within tolerance of .020 mm. when I slide the gauge under the tip, it slightly raises! This was the top cylinder. I did not check the other two because I thought I was good to go. I have about $150 in the carb rebild kit, new floats and feul pump. Would you reccomend anothe $40 for set of reeds and gaskets at this point?
Original problem is engine would not idle very good! Could not get below 1300rpm and top carb would not choke out during adjusting screw all the way in until it was lightly seated. Engine kept on running!
Thanks in advance!
Rusty
