how do i get the bolts out of the lower unit,to replace the water pump,they are stuck.........thanks
T tater44 Recruit Joined Jul 14, 2009 Messages 1 Jul 14, 2009 #1 how do i get the bolts out of the lower unit,to replace the water pump,they are stuck.........thanks
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Jul 15, 2009 #2 Re: stuck bolt try some heat.
W wilde1j Vice Admiral Joined Apr 15, 2002 Messages 5,964 Jul 15, 2009 #3 Re: stuck bolt And when you reassemble, put gasket cement or nonhardening Permatex on the bolts so you will have a decent chance to get them out again.
