swimmin' for shore
- Oct 25, 2004
- 490
I had a 1969 mercury 35 hp all but given to me the other day. I tested the compression at 145 on each cylinder, put it on a stand, and wiped down the motor. Everything looks okay, but I started to experience a few issues with it, and I want to see if I can try to solve at least some of them here before I spend any money with a mechanic. I'm going to take these in order of what I at least think is most important.
1. The outboard won't shift smoothly. I took the cables off, and they're a little old, but they're free. I got in there with a little WD 40 and got the shift rod to move back and forth a little more freely, but when I put the cable on, it shifts really, really hard. I can see that the lower unit was cracked and welded, but the guy said he had run it for another year before giving it to me, and that the weld repair had worked fine. It's leaking a little bit of oil though, so I'm wondering if the whole repair wasn't quite as good as he seemed to think. In any case, if we can figure out the shifting and I can verify that the lower unit is working okay and that I can repair this, we'll be ready to move to the lack of spark. Thanks in advance.
