Mercruiser 4.3 exaust manifolds
cory43112
Have a '99 4.3L and the starbord exaust manifold gets fairly warm to the touch while the port side stays cold. Normal or not? thanks
directorsusa
Re: Mercruiser 4.3 exaust manifolds
you probably have blockage at thermostat housing. I had the same problem, but burnt up my exhaust hoses because of pieces from old impeller blocked water flow to exhaust.
z284u2try
normal. I say if you can hold your hand on it your good.
My boat has always run the same way.
I beleive it is do to how the water is routed in the engine
