Re: Cooling system question
Removing a thermostat in a motor will cause it to run cold. Efficiency will suffer, but the motor wil not be damaged.
Why do you want to remove the 'stat? If it is overheating, you might fix the impeller problem or heat exchanger problem, before it gets worse, and fries the 'stat-less motor.
