Re: Understanding gearing
gearing is not brand or model specific. gearing is motor specific. a 4 cylinder motor cannot produce as much torque as a v8, in stock form anyway. if you take a full size truck, put a 4 cylinder in it, it will take a long time to hit freeway speed. now, if you put a v8 in same truck, with same gearing, that truck will hit freeway speed alot faster, because the v8 produces more torque at lower rpms. if you take that same truck, but change the gears, with 4 cylinder, it may not get to freeway speed as fast, or keep up with the v8, but it will reach a higher speed faster, if the gears are right. a v8 boat motor will work with 4 cylinder gears but not for long. it will take off quick, but will reach top speed very fast because the gears "run out", so you end up not being able to use the motor's full power. now, a 4 cylinder will work with v8 gears, but it will strain the small motor too much, and will never reach a cruising plane, as the motor will be doing all it can to just move the boat. hope this helps and isn't too confusing.
