Anyone have a Johnson 2000 25 hp? I need a picture.
Terre_D
Anyone have a Johnson 2000 25 hp 2 cylinder? I need a picture of where the fuel line from the fuel connector goes to the fuel pump. I just picked up this motor but the the fuel line is missing and I need to see how it connects and what else is missing. Is there a fuel filter inline?
In help would be appreciated.
Thanks
Terre
tashasdaddy
Re: Anyone have a Johnson 2000 25 hp? I need a picture.
Model # please.
cougar1985
if youre just wondering where on the pump it goes it goes to the larger connector.for routing i think you can get a idea from the brp site(parts).
G DANE
Mine goes around the back of the powerhead, and up to the pump. 1997 25 HP
G DANE
No fuel filter except for the one in the pumps lid, but you can easily ad one if you like, definately a good idea, and plenty of room for it. Remember to turn it the right way, most have an arrow casted in. the 1997 is the exact same motor.
tashasdaddy
the reason i ask for model #, is there is a 2 cylinder and a 3 cylinder 25 made in 2000.
Terre_D
Mine's the 2 cylinder version.
Thanks
blksmith1
I have that motor.
Just had a fuel pump problem. The spring return assist for the diaphraghm pump twisted sideways and blocked a flapper valve.Made it back to the launch though.
My fuel tube from the connector goes around the front down low under the carb and connects to the outside most nipple on the pump. This is the one with the thumb screw and filter screen.
Take care
Tom
Terre_D
What size is the i/d of this hose. Johnson parts page is down right now and I cant see it.
Terre_D
Thanks for the help blksmith. I ran the fuel line from the pump to the connector like you said only to find out that the connector was broken. Ordered a new one.
