Mikejillryan
- Jul 17, 2009
- 1
Hey guy's I have a 1998 force 120 outboard. While on the water today I started experiancing a vibration with the motor. I raised the motor to check the props and except for a little bit of seweed, it seemed fine. I lowered it back in the water and same vibration. The more rpm's the more vibration. I have a four blade composite prop and one of the blades has a small chip off one end of it. Could this be the cause of my vibration? I removed the prop and checked the shaft everything spins and moves freely? I don't want to just change this blade put it back in the water and experiance the same problem. Is there something else I should look for?
