I just bought my first boat and need some help. I have a 1958 starcraft 15' and it is not even geting to a plane. The first day out on the lake we were able to get boat up to around 30mph then after a few minutes was only able to get up to about 10mph still with WOT. Checked for spark at an idle and found that #2 cylinder didn't drop in rpm with spark plug off. Took home and replaced spark plugs, checked for spark on all 4 cylinder and I have spark checked compression on all 4 cylinder, compression on all four between 120-125. Thought maybe clogged fuel pump diaphram/filter but after inspection, looked good. Spark plug wires are good. I have tried to squeeze the bulb on fuel line while at idle and WOT and didn't find much of a change, bulb was firm. Not sure if my coil would cause this or if maybe a timing problem or a carb problem. It does have two carbs by the way and they are synced together. I find that when i have boat in neutral and use the choke/lever next to my throttle up front it will hit well into the upper 4000's but as soon as i put in gear and WOT boat wont hit upper rpm's. Plz help
