Jynxs boat
- Jun 28, 2009
- 11
O.k. o.k. I diddn't want to ask for help, but I feel like I'm about to get into some deep doo doo if I don't.
I'll start by telling you I bought an 82 beachcraft with a 2.3L omc motor, and the original stern 982740. When I got it it didn't run, lights diddn't work, ignition wouldn't turn, sump pump wasn't hooked up, speedometer diddn't work, and the tilt wouldn't tilt. This was two weeks ago. So far, I got the motor running, the lights workin, the ignition, and sump pump all workin well. Tilt is ok, I gotta figit with the switch but it drops eventually. Speedometer still a no go.
Heres where I'm at now. I got it the water, dropped the prop, and slowly brought it up to speed, and arrived at a fishing hole catching some nice rainbows.(4lbs) Well I thought I'd head back, started her up, and put it gear.
I got about 40 feet, and thought I would open her up a bit, and as soon as I did, I heard a winding sound, and I noticed alot of splasing at the top of the sterndrive, no spin on the propeller.........luckily two girls in bikini tops towed me in. embarrassing but fun.....
When I got it in the garage I orginally thought I had a problem with my lower, so I took it all apart, and notice the gear that connects to the clutch wasn't engaged at all, so I thought thats why my propeller wasn't spinning. I fixed that and the linkage is perfect, and the propeller spins when I put it gears. I thought I had it all figured out.... I went back to the lake again today, got it in the water, dropped the prop, started right up, but I got the same winding sound and no spin on the prop. As soon as heard it I thought crap it wasn't the lower its the drive shaft in the stern from the motor. Someone please tell me I'm wrong, and that I missing something small. I'm gonna get back at that thing in the morning.
