my day in the barrel
ScottinAZ
Master Chief Petty Officer
Well today we took out the squirt, the wife and the ancient Invader. All was going good until the engine started running on one cylinder.... (oh crap, long ways to paddle) pulled out of the channel, popped the cover, and lo and behold, I didnt secure a plug. The drain plug on the lower carb had rattled itself loose, and was residing under my starter, just where I couldnt get to it. Got the boat back to the dock, and I tilted the motor up to get the plug, but no use, I didnt have the tools I needed to remove the air intake to access the plug hole in the carb.
Total time on lake: 1 hr
Total time underway (on own power): 10 minutes
Total time futzing with motor at the lake, on the trailer: 45 minutes
Drive time to lake : 1 hr
Time to repair the motor when home : 5 minutes
Having proper tools: Priceless
Double checking that you tightened the drain screws on the carbs after overhaul : Even more priceless....
david_r
Re: my day in the barrel
i carry a small tool box in the bilge area with a small socket set and various screw drivers and wrenches.............. i alos carry 2 extra sets of plugs an extra power pack 2 coils (4cyl 115) and lots of zip ties, elec tape, duct tape, fuel line, fule line clamps , fuses, extra fuel connectors, brass fuel line splice, etc...........
ive been broken down before......... well sort of.......... im usually not broken down very long............. i also use one starter/deep cycle batt for starter and one for troller , and cheap jumper cables.
ps make sure you get either a flexible or extendable magnet too :D......... i have had bolts, nuts , and washers run from me too.
ScottinAZ
I had screwdrivers, but didnt have a 5/16 socket, or wrench with me. I will be getting a tool kit that is "expendable" here soon. Fool me once.........
At least I wasnt the poor bastard next to me on the ramp. He just forgot his plug, and filled it to the gunwales with water......
david_r
yes dont buy anything you arent willing to drop over the side.......... i was adjusting the trim bar on my lil '64 18hp.......... dropped the dang thing in 8' of water.... in the winter time. i offered my buddy $100 if he would at least try to find it :D. he said "man if you give me $1000 i will come up with it, otherwise im not getting in that 42 deg water" ................. its till out there somewhere.
ive also been the poor sucker who left out the plug :eek:
meals on reelsjello2
well at least your boat isnt a bathtub right now mine is full of water 2 in fron the top i just put in the new transom and its siting outside in the rain...LOL
Home Cookin'
a fishing magnet (no not a type of lure, a strong magnet on a string) is great to have at the dock. Won't pick up stainless or aluminum obviously but good for most dropped tools and things.
ScottinAZ
unfortunately the screw is stainless. I didnt want to tilt the motor, for fear of losing the damn thing in the water. At least where it was, it was recoverable... A set of gripper claws is in order I think, but better yet, howzabout I tighten the damn drain screws.
j_martin
The devil's in the details. Brilliant mechanical work, undone by one little detail.
Thanks for the story. I'm sure it'll help you heal.
John
ScottinAZ
well, this time, y'all can learn from mine.....
