Re: 3.0 - what closes my choke?
For reference, here's how I assembled mine. When you're staring into the side of the choke/carb with the coil assembly in your hand, the end tab of the coil went on the right side of the lever inside the choke housing. That lever is atttached to the choke shaft. Once the tab is on the right side of the lever and the coil is inserted into the housing, you can then rotate counter-clockwise as needed for adjustment. This way as the coil heats, it pulls the tab away (clockwise) from the lever and allows the choke plate to open using it's own weight & leverage on the shaft. As the coil cools, the tab pushes on the lever (counter-clockwise) and closes the choke. Note: The choke's shaft must be very freely moving. I thought mine was until I cleaned it and THEN it was free to move. If you have the coil removed, your choke plate (inside the carb opening) should easily fall completely open. If you reposition that plate with your fingers and let go, it should fall open. It should be moving that freely because that's what actually opens it. The coil doesn't open it... the coil "prevents" it from opening by pushing it closed to a varying degree depending on the temp of the coil.
Once the coil is inserted with the tab on the right side of the choke shaft lever, you can then rotate the coil (holding the outside housing of it) counter-clockwise and you should see your choke close. Once you adjust it to your preference, tighten down the three screws, you should be able to turn on the ignition and my choke fully opened (due to the coil heating up and relaxing its tension on the choke lever) in less than a minute or so. As we were discussing earlier in the thread, it's actually the weight of the choke plate (inside the carb), the linkage weight, and how it's attached to the horizontal shaft that makes the choke open (gravity and offset weight of the parts). The coil does not push it open. It pushes it closed, so when the choke is fully opened, the coil is warm, "retracted", and pushing at zero force on the choke's shaft.
That's how mine worked.
