1999 johnson 15 hp - location of pee hole
geedubcpa
Is the pee hole on the later model motors on the back of the motor vs the front - When i hook up the water, I am getting water coming out of the back of the motor vs the front - hope this isn't a dumb question but I dont see a hole on the front.
Vic.S
Re: 1999 johnson 15 hp - location of pee hole
Maybe I'm being dumb but aren't pee holes normally at the back?
geedubcpa
Ok I figured this out - the pee hole is in the motor with a rubber tube leading to the lower casing - since I had the lower casing off it was not acting like I thought it should - end of amature mechanic story........
