motopsycha
- Jul 17, 2009
- 2
I've searched the forums and have not been able to figure this out yet.
History: I have a 1988 140 V4 . It was purchased used, along with a boat from a dealer two years ago. I was told the VRO had been disconnected and I would need to mix gas - no problem. After running it a couple of times I got the "low oil" alarm (a short beep every 20 secs or so). I noticed the oil tank had some oil in it and I added a bit more to quiet the alarm. Observation since that time indicates it is drawing oil off the tank consistently.
I took a look at motor and have discovered the following:
- VRO2 pump is plumbed as it should be
- the 3 wires coming out of the pump are still connected to the mating connector - except for the gray wire. it was cut and the pin missing from the connector
As I understand it this gray wire from the WRO should be the one to transmit a "no oil" alarm Correct?
When I reattached the gray wire I get a rapid warbling alarm from the control box when the key is on. I found reports of other with a similar issue caused by a fault in the oil tank sensor that could be remedied by disconnecting those wires. I tried this but the rapid alarm is still present.
One very odd thing that happened during my trouble shooting is that I have been able to connect this gray wire from the VRO without the alarm going off once in a while. Once successful, the alarm does not come back on unless I disconnect and re-connect it again.
Could their be a fault in the VRO pump that would cause this?
Is there any way to test the functionality of the
"no oil" alarm?
Your help is appreciated.
"no oil" alarm?
