Hi all,
I have a '97 Evinrude Intruder 115 hp. I've read several similar threads, but have yet to find the answer to this question. I just had the throttle cables replaced over winter, but this problem has developed since. The throttle moves smoothly and easily from neutral into trolling position, but then gets very stiff as you try to accelerate from there. Also, it has recently developed an issue where when cruising at a certain speed, the motor will suddenly accelerate quite quickly without moving the throttle hand control. Once I compensate for this the motor will run fine for a while and then slow down just as rapidly. I'm having trouble determining if my problem is in the cable, the motor linkages, or the control box. I'm trying to learn terminology, etc, but I've got a steep hill to climb so thorough explanations are extremely appreciated.
Thanks for any help you can provide.
