Re: Broken bolts in lower unit 98 dt140
As long as you have removed the water pump base (it holds the upper drive shaft bearing and shaft seals) you would have better luck by heating the area. If some of the bolt is sticking out enough to get vice grips on you can rock the bolts back and fourth after heating and cooling it. Probably no bolt showing though.
I would:
(1) bang the crap out of the bolt top using a punch
(2) heat it up, then cool it with water
(3) bang the crap out of the bolt top using a punch
(4) heat it up, then cool it with water
(5) repeat several more times
(6) soak with penitrating oil
(7) drill out the bolt with the correct size bit to EZ out, drill SLOW, I have smoked too many bits, use a left handed drill bit if you can
(8) cross your fingers and hope the EZ out gets it, I've broken them and it sucks
(9) it non of the above works you can drill the bolt with a bit almost the same size and try to collapse the threads which is tough and messy then retap the threads
(7)
