Extremely frustrated here...
I've gone through a lot of pain this season with the cooling system on my OMC equipped boat. So one of the things I did this year was replace the water pump components in my cobra outdrive including impellar, plate, and gasket. Once I had all my cooliing issues squared away, I was able to run the boat for a half an hour at 170* on muffs. So now the boat is in the water and when I finally had time to go down and take it out, it heated up to 220*!!!.
I took the hose off the power steering cooler to check for water flow, and there was practically no flow! Now, what the hell is that all about??? The boat didn't have a chance to go out anywhere and the pump failed? Could there be some other problem? I'd like to be relatively prepared with solutions because it will cost me $200 just to have the boat pulled out so I can work on the outdrive.
