Carb Cleaning Tip
dthrckt
Took the carb off a '59 bigtwin two days ago. It was so gummed up that I had to put the whole carb in a vice and tap on the bowl a little to get it off. It was pretty bad. The inside was entirely coated with a hard brown film.
I immersed it in gumout carb cleaner for two days. When I took it out this morning the carb cleaner was a little tinted but most of the film was still there.
I scraped and scrubbed, tried aircraft remover, acetone, lacquer thinner and even put it in the dishwasher. Most of what I could reach was clean but the jets were still dirty and I don't have any pipe cleaners.
Finally I sprayed it with oven cleaner, came back ten minutes later and it was TOTALLY clean. I rinsed it with water and watched all sorts of crud come right out of the jets. GOOD STUFF!
It did seem to darken the aluminum a bit so it might not be smart so soak it too long.
Vic.S
Re: Carb Cleaning Tip
Depends on the oven cleaner. I would not use a caustic soda based cleaner on aluminium items. A methylene chloride based carbon remover however would be perfectly safe on aluminium. The allowed constituents may vary from country to country (or even state to state) . Check the label!
dthrckt
yeah, i really should have said 'at your own risk'
the can i've got is made by 'powerhouse' - says it contains sodium hydroxide (lye) - which I'm pretty sure reacts with aluminum...
i thought i'd experiment because i was about ready to toss it in the trash - now it looks new, is on my motor (needed its solenoid mount) and running in a barrel :D
lindy46
Yup - sodium hydroxide does a good job of eating aluminum.
daselbee
I bet it would work great on the plastic carbs. Lye will not harm plastic, just look to the lye based drain cleaners that go through plastic drain pipes...
I am going to try it on a plastic bowl that has "ethanol poisoning" deposits of dissolved rubber....
But thinking, it will not get rubber depostis off either...consider the warning to always use rubber gloves for hannd protection...
Will post back with the results anyway.
Vic.S
Yes sodium hydroxide = caustic soda
The yarn they used to tell where I worked at one time was of someone who hung a carb (of his car) in the caustic soda dilution tank in the water treatment plant overnight. Next morning all that could be found were the brass jets etc sitting in the bottom of the tank.
dthrckt
http://howto.wikia.com/wiki/Howto_i...n_having_water,_aluminum_and_sodium_hydroxide
is it just me or does that sound really dangerous?!
I'm doing a little experiment on a piece of the carb that had the same brown film. Sprayed w/ oven cleaner and wiped it off 30 seconds later. All the brown crud came off. Measured w/ my micrometer 3 times and then immersed in a cap full of the same stuff. I'll measure the difference after a half hour, hour and 10.
You can bet a carb I use will never get dirty enough to need something like this but I bet it isn't the last time I use it on a parts motor!
As for plastic, I'd do a spot test on the outside of it first. There are so many different kinds of plastic...
Vic.S
Dangerous in as much that caustic soda is extremely corrosive to skin and flesh. Do not use it without eye protection because apart from being so excruciatingly painful as to make it impossible to open your eyes to wash it out it will cause permanent damage.
dthrckt
i was thinking of birthday candles and hydrogen balloons...
http://www.youtube.com/watch?v=d1HxU0-Jpj0
I suppose that's 'flashy' but not likely to start a fire
the experiment had some pretty boring results - i continued to top off the cap full of oven cleaner until it was filled with liquid instead of foam - after 24 hours there was no change in size that I could measure - the micrometer measures to .0001" but I would say that my measurements were +- .001 due to the slight taper of the part (main jet housing) and human error. The aluminum turned a dark gray. The brass seat turned black but that wiped off pretty easily.
YMMV
