1984 Evenrude 70HP Removing Starter???
craftsman1987
i have an 1984 Evenrude 70Hp motor and don't see how to remove the starter. I removed the 2 bolts on the right side but starter is still solid. is there more bolts some where? do you need to remove the carbs to remove it? any advise is welcome.
petryshyn
Re: 1984 Evenrude 70HP Removing Starter???
there is one more bolt facing the front
petryshyn
no, but you may have to remove the silencer (black plastic carb cowling)
craftsman1987
ok, thanks. will i need a new gasket then to replace that cover?
petryshyn
Its always a good idea to replace gaskets.
craftsman1987
ok, thanks for the help. it's exactly what i needed for now.
