Well what am I doing wrong?
Last night I blew a hole thru a piston on my second engine for the season.
Running a pair of 1996 200 HP Ocean Pro. Mid June a lost the port engine to a piston failure. Upper let piston when looking from the back of the boat. I found what was supposed to be a good used engine to replace it. Last night blew the replacement engine in the same way. There is a hole thru the upper left piston.
Prior to trusting the VRO I ran the engine from a can and collected the gas/oil being pumped out of the VRO ?had good color, I then batch mixed my Aux tank 50:1 filled the oil tank and marked it , VRO pumped oil from the tank at the expected rate ? matched with the other engine in the pair.
New fuel filter was in place and running no ethanol gas with sea foam mixed in.
What am I doing wrong? Hard to believe this is just bad luck. ? Same cylinder on both units?
Oh and broke a shaft on the starboard motor in the spring ? it?s been an expensive year.
Looking for a good used pair of 200?s
Thanks
SBLGFD
Thanks
SBLGFD
