Re: 1985 force,boyesen reeds
Boyesen Reeds are made of carbon composite. If your engine is in tune, fuel delivery system ok and timing correct, they will work and give you a better idle and better response at the lower rpm range.
If your engine is not in the condition stated above and it should backfire through the intake, the boyesen reeds will be destroyed. They cannot take the occasional backfire that comes from say, starting cold without engaging the choke.
Yes, steel reeds can do damage to an engine if they come apart. However, the conditions that damage them, overrevving and constant backfires, are controllable by you. Maintain and operate your engine properly and you won't have any problems with stock reeds.
There are exceptions to this. Recently my engine ran lean due to a hose connection coming loose, it allowed the engine to backfire a few times and it backfired a few more times as I was troubleshooting it. The result was bent reeds in excess of the .020 gap that is allowed and a poor running engine. However, they did not come apart.
Considering the fact that they are almost 25 years old, I think the OEM reeds work just fine. (plus six of them only costs $54)
John
