i have a 1976-1978 35 hp chrysler outboard that cranks slow. i pulled the plugs out and the motor spins over fine. the cylinders each have 100lbs of compression and i have bypassed all wiring to the starter. tested the starter on the bench tester and it pulls 46 amps at 10.45 volts. also checked amp draw when mounted on engine and it pulls 100 amps. seams to me like the starter just does not have enough torq to turn it over but ive never ran into this before. any suggestions would help.
