KTOWNCABBY
- May 31, 2009
- 8
I Had A Small Leak Around The Impeller Cover Of My Sea Water Pump On The Front Of My Motor When The Motor Was Under Power. I Tried To Tighten The Screws And One Snapped In The Housing. Can This Be Drilled And Tapped While The Boat Is In The Water? The Marina Mechanic Wants $300 To Pull My Boat Out Of The Water To Do The Repair Plus The Repair Cost!! Which Hose Do I Need To Clamp Off So My Boat Doesn't Flood While I'm Doing The Repair. Any Help Would Be Really Appreciated!! The Motor Is A 1988 5.7l Aq 271c Volvo Penta
