help!!! 1959 johnson fat fifty
ron12
so i thought the motor was gonna run today got the magneto unit from norm boddy what a great guy. the motor tryed starting but immediattly died.then i tryed it again and it backfired pretty good and then there where flames coming from the lower unit. would that be from the motor getting flooded or ? any ideas on how to fix that?
thanks again,
ron
F_R
Re: help!!! 1959 johnson fat fifty
thanks again,
ron
It is out of time. Maybe the belt is installed a tooth or more off. Or the spark plug wires are mixed up. Or the flywheel key is sheared.
ron12
how do i tell for sure if the flywheel key is bad?
Ron, The flywheel has a TDC timing mark on it. The block and recoil starter have timing marks on them as well. These are in the rear of the motor. Line them up and stick a screwdriver in #1 Plug hole and see if piston is at TDC. If not TDC, flywheel key could be sheared. Make sure when you reinstall flywheel it is torqued to 140# ft-LBS. You might check with Joe Reeves, since my number may be a bit off.
Also, when the timing marks are lined up, move the throttle until the timing mark on the distributor pully base lines up with the punchmark on the distributor support. Now the distributor pully timing mark should line up with the timing mark on the pully base. If not the timing belt is wrong. Throttle cam should just touch carb roller at this point as well.
The second set of points has a second timing mark on the pully base, where it faces the block. Points should just open as timing marks aliign.
ron12
ok cool i will do that and see what happens. thanks for the help.
1946Zephyr
Flames coming out of the lower unit? Sounds awesome.:D
ron12
yeah it was not awesome at the time but now that i look back it was kinda funny.
