Motor is surging and not maxing out.
pamunkey
Yamaha 150 is surging at low rpm and is running at 4600 at wot. instead of 5000. carbs were rebuilt last year and have only run 2 tanks thru it since. plugs and filters changed with no results. Whats my options w/out rebuilding carbs again if possible and is this something resulting from 10% ethanol in the fuel.
robert graham
Re: Motor is surging and not maxing out.
sounds like a fuel pump/pressure/delivery problem. check fuel pumps.
jbelcner
Are you getting spark from all plugs? This being a 150 hp you will have 6 to check and should have one coil on each plug (depending on the age of the motor). I would test to ensure that you are getting fire on all 6 cyl.
The bad news could be a bad cyl all together. Have you put a compression test on these yet? Not sure what the compression should be, but I think it is about 120 PSI. You will have to consult a maunual or a mechanic for the specifics.
Hope this helps.
JB:cool:
pamunkey
Thanks for the input fellas. I'm going to start the troubleshooting this week and hopefully it's a simple fix.
