The boat ran great and this happened during one outing and I can't figure it out.
it has a miss (runs rough) from idle to 1500 rmp, above that it smooths out and seem to have good wot. I can ski with it.
i have replaced: plugs, wires, cap, rotor. It has petronix ignition and i put the points back on with no change.
running at say 1300 rpm and pull any plug wire and it will run much smoother (does not matter which plug wire). The timing is set right at 8 degrees.
my compression test showed all cylinders pumping to 145-150 on 8 revs. each one had a min pump of 60 PSI on the first rev.
I don't know what else to do. the boat has a new fuel pump and lines also and a new coil.
