Kiggsia
- Sep 18, 2008
- 98
The used 16 foot Lund boat with 1987 40HP Evinrude has an unbearably strong pull to the right which of course becomes stronger with boat speed. I found the small trim rudder over the prop set to trim to the right and thought that was the cause. There is very little travel in this adjustment, but I set it "all the way" in the opposite direction, tested the boat, and there was no difference. I even removed this small rudder and retested and there still was no improvement, still this very strong pull to the right which makes my arm sore in hardly no time at all. I doubted that the fish finder sensor mounted to the right of the motor would cause the problem. And if the boat trim is too low in front causing porpoising, it would sometimes pull to the left I would think, and only when thrusting downward, but it is a steady pull to the right even when the water is calm and the boat travels steadily. Might anyone know what could be causing this? There doesn't appear to be anything else out of alignment. The prop doesn't appear to be bent. If my prop pitch were too great could this cause a pull to the right?
