I just bought a used boat (1988 Seaswirl) with a 120hp Johnson (J120TLCCA) it runs great. When I run it on muffs it seems ok. I took it out yesterday to check things out and when I get going at WOT, the buzzer starts buzzing (buzz, buzz, buzz, ect.) as soon as I lower the rpms the buzzing stops. The motor does not seem to be running hot (which is what I thought the buzzer was installed for), although there is no temp gauge. as a matter of fact I have: RPM, Tach, Volt, Tilt, Fuel, and Speedometer but only the Volt Gauge works, could this be why the buzzer is going off (because all the other gauges are basically saying the motor is not running) I have not even started to troubleshoot as to why the gauges are not functioning. I did notice the tilt gauge works with the key off but not with it on, is the normal? Seems strange to me, but then again it seems odd to me they put all those gauges in and no temp gauge, which to me is more important than most of the ones they did install.
