CaneCutter79
- May 24, 2009
- 454
My boat is a 79 model with a tri-hull up front. The back portion of the hull is not as deeply "V" shaped as newer bass boats so it sits a bit flatter and has no contour towards the front of the bow. In other words, the keel is pretty much level and straight until it reaches the bow where it begins to taper off and upward. So, I cannot get a lot of bow lift due to the hull design.
Here are some pictures of my setup. The motor is mounted right on the flat style transom so it cannot go any lower and I suspect it should be lower because in sharp turns and WOT, the prop slips and has "blowout". I can only trim the motor up just a little bit before the prop slips.
What I have shown in the pics is the trim settings at WOT. This is just above all the way down ont the trim. Does the motor height appear to be too high or too low? I feel it's too high. I cannot use a jackplate to lower the motor as it is as low as it will go. Currently, the bottom plate rides just above the water's surface when on plane at WOT.
ALSO...
Which plate is my cavitation plate? I have to plates. The bottom plate holds the hydrofoil (which helps hole shot). Everyone has told me to loose the hydrofoil but the boat actually runs faster with it and the hydrofoil is out of water and above the surface at WOT so I cannot see how it's causing drag or causing the prop to slip at WOT. If the hydrofoil is above the surface, is the motor too high?
One last thing....
In theory, prop blades should always should be under the water surface correct? If your prop blades are above the water plane/surface, that will create slip and prop issues correct?
I believe this sketch roughly shows how my prop is placed at WOT.
ALSO...
One last thing....
