Carbon buildup in Evinrude 225 Phic
destinee
while heading out to Catalina still in the Long Beach harbor my "out of oil light" comes on. I come to find out it is carbon buildup. Any suggestions on how to treat this issue and also on how to prevent it.
noelm
Re: Carbon buildup in Evinrude 225 Phic
OK, how do you know it is carbon build up? do you have oil in the tank?
destinee
At first i really didn't realize it was "no oil" light and alarm going off. I just assumed it was "low oil" but when i checked it was pretty much filled. When this happens the motor goes into a low rpm mode. I restarted the motor and headed out with no problems but of course an un easy feeling through out the day. I ended up taking her in and this is what the mechanic told me. I was hoping to learn how to treat this myself and also how to prevent it.
tashasdaddy
no such thing as a high carbon alarm.
J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat and fuel restriction alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
WHAT YEAR IS YOUR MOTOR?
