natemoore
Master Chief Petty Officer
- Jun 13, 2009
- 844
Read this excerpt from the #8 manual.
"1. Apply Loctite 8831 to outside diameter of all oil seals....
2. Both water pump seal lips face water side....
3. Fill space between water pump oil seals...
4. Install crankshaft seal with seal lip toward engine block.
I've received conflicting information, and the mechanic who installed these on on my engine did one facing in and one facing out, so that was no help.
Based on the way the front crank seal is installed--and it can only be installed on way--the author of the #8 manual calls the side of the seal with the garter spring the "lip."
Without getting bogged down in terminology, I've provided two drawings. The first is how I interpret the manual. The second is the alternative (and I believe incorrect) installation.
Do you agree?
Do you agree?
