3 Bank OnBoard Charger Question
Boss Hawg
I just bought a bassbost with the above & was wondering how long it should take to turn all 3 lights to green with knowing all 3 batteries are at least 75% charged :confused:
Reason i ask is i had it pluged in for at least 12hrs & all i got was 2 green lights :(
flargin
Re: 3 Bank OnBoard Charger Question
depends on a couple of things.
if 75% = 12.3v (12.0 v is considered about 50% drained) then you may have troubles. A couple of reasons it may not be a problem is:
1. something is draining at the same time you are using it (or you have some loose connection or corrosion)
2. The battery is really big, & the charger is really small
1 is the likely problem, unless it is that the battery is dead.
if you consider 75% = 9v... keep waiting, likely fine.
Silvertip
Depending on what the current rating of the charger is and how deeply discharged the battery is, it may take far longer than 12 hours to charge it. For all you know that one battery may be bad. Have them load tested.
Boss Hawg
Had them tested- All good :cool:
Plugged them back on the 3 bank & 2hrs latter got 3 green lights :D
Guess i just did'nt give it enought time :redface:
