Re: Scout 187 porposing
If I'm reading you right you've got the max size engine on (150 hp 4 stroke) verus the 115 that used to be on it?
Anyway, my observations over the past three seasons with our Scout 170 Dorado is that the boat is more prone to porposing than most outboard boats of its size. There is a very fine line on my boat between optimal trim and beginning to porpose. Sometimes, although rarely, I've found optimal trim under some sea conditions can induce it if those conditions change. Say if I've come in from some open chop to flat water in a protected bay. It's all very controllable -- just more sensitive than what I'd consider "normal" on a boat this size.
Now, that's with running a 90 hp 4 stroke on the hull, well down from the 130 max rating. From this might one reasonably conclude from the comparison of our two similar boats that it's your bigger motor putting you over the top?
Other random thoughts:
I have also often wondered if their Air-Assist hull design contributes to this tendency in my boat. ("to combat the problem of static stability, common on small boats. With additional longitudinal buoyancy, the Air-Assist hull increases static floatation and decreases time to plane and also vastly improves overall handling characteristics..." - Scout sales literature) Although you would think they would have discovered this long ago if it was a factor instead of crowing about improved handling...
Also, did you ever run it with the 115 and if so, did you have the problem then?
You also mention having your entire family on board. What about just you or one other? Any difference?
