jamesd_williams
- Aug 29, 2009
- 1
I have a 1997 Sea Ray 185 with a 4.3 engine, 2 Bl carb. The timing mark on the timing cover of the 4.3 has a single V shaped indentation. I presume this is the TDC mark...
Do I need a timing light that shows advance to time the motor?... I put the Thunderbolt 5 ignition into base timing mode, but there is no mark for 8 degrees on the timing cover.
If I need a timing light that allows for advance, what's a good brand, and do I set the light for 8 degrees and set that up to the (TDC) mark on the timing cover?
I am used to automotive timing covers... with marks for 0 to 12 degrees.
Thanks for your help!
Jim
Jim
