Temperature check on 1976 Johnson 25 HP (25R76E)
andreipou
Is there an easy way to determine temperature of the running power head?
Manual says to use some heating sticks 125F and 163F, but I think it is old.
Is there something inexpensive?
What should be the right temperature?
Thanks.
Whoopbass
Re: Temperature check on 1976 Johnson 25 HP (25R76E)
Harbor freight has a cheap laser pointed thermometer for $8.00. You just about have to be touching the surface of the item to get an accurate reading but it does seem to work.
There is also a sticker with some type of built in thermometer that you can apply to wherever and get a temp reading. They sell them at Motorcycle shops. I think there about $6 for 3 stickers.
My Johnson 35 runs about 140-144 degrees in a barrel.
dade61782
they are called temp sticks you can get them at a welding supply. they dont melt until the specified temp is reached
andreipou
Good stuff!
Thanks.
