Re: 1992 Mariner 115hp - Regulator Rectifier???
The voltage regulator/rectifier is not part of the ignition circuit and won't keep your engine from starting. However, it is designed to blow if the battery cables are reversed. In theory this protects the more expensive switchbox.
It doesn't always blow fast enough so if that happened you may have damaged the switchbox.
Stator spike can blow a rectifier.
The only way get on track with this problem is to do the basic resistance checks and come back with the details. The procedure is in the Seloc manuals with the specs for your system.
There is absolutely no connection between the switchboxes and the battery. I've been in electronics and electrical engineering for 40 years, and I have no idea what a stator spike would be. I call BS.
Now, to the problem.
The stator has coils in it, called charge coils, that provide power to the switchboxes. There are 2 sets of them. It has another coil in it that provides power to the battery charging system. That's the yellow wires.
You can do some ohmmeter testing to find radical problems in the stator. If a coil is open, or shorted to ground, it is definitely bad. This testing cannot find a single shorted turn, or a low point short to ground in a charge coil. Both of these faults will cause the system involved to fail.
Tests at cranking speed with a DVA will find the above hidden faults. That would be the next step in this process. Believe me, a DVA and a manual are a good investment at this time, and will be paid for by preventing just one mistep that installs an unneeded part.
If you find everything has gone to pot at once, the most likely reason is a mechanical strike by a loose magnet, loose stator mounting, or a bad top main bearing. If you suspect that, you can pull the flywheel (properly please) and look for mechanical damage. There should be no sign of contact anywhere on the stator. If you find mechanical damage, you've found the problem.
hope it helps
John
