I recently purchased a 1975 4hp johson motor for $150, it is the weedless design which I didn't know at the time I purchased it. Anyways I have got another post out right now in trying to get it to run better for the fishing season but I just wanted to get some opinions on this motor before I spend $$$ on it.
I have a 14ft double eagle f/g boat with a 1995 60hp johnson, Iam not sure how much the boat weighs off hand picture below Iam sure more educated people could make a reasonable guess. Anyways Iam prepared to go through this motor in the off season buy a manual, rebuild the carb, fuel pump, maybe give a good tuneup to the ignition system etc, however I want to make sure this engine when tuned up and in good condition will be enough of a kicker/backup motor for my boat. So far it isn't cutting it for me but it coughs and surges etc right now and is not reaching its full potential at all. So what do you all think will a 1975 4hp motor be a decent enough motor to use for trolling and as a backup motor just in case if in good shape and well maintained? One thing I think that is holding this motor back is the 2 blade weedless plastic prop, and I would like to replace it with a 3 blade metal prop meant for trolling etc. My dealer says he can't get anything else for it but the plastic 2 blade due to the hub designe, will I be able to get one from a prop shop?
By jaymasta
By jaymasta
