jonjoshaddison
- Aug 30, 2009
- 5
Just bought a '98' Bayliner with a number of issues; starter bolts broken, bad gimble bearing, and bad floor. I have already pulled the motor and fixed the starter issue, cut open the floor and removed the rot, pulled the gas tank and cleaned it, and removed the outdrive. Now I am ready for parts and here are my questions... Aftermarket Marine has good prices, but are the parts good quality (bellows and gimble bearing)? Is there anything I should be careful of when pulling and replacing the gimble bearing? I don't want to damage anything. I have a wide experience on everything from Hot Rods, to motorcycles to skid steers, but no experience with out drives... My last question is regarding the type of fiberglass resin that I should use to put the floor back in, polyester or epoxy? Thanks for your help.
