scutly
- Aug 20, 2009
- 368
Re: OMC I/O problems
no it definitely is not
The impeller is fine. :
have you tried the marina on US 6 and 9?
they dont have alot there but they are pretty close to you...
there are several marinas near me but they are all expensive...they charge 95.00 per hour and up to 150.00 per hour on odd-ball stuff...
you still doing boat interiors...? I am looking to get a few things recovered myself...
I would look at replacing Cobra drive with an SEI conversion kit.
Did you ever drain the drive?
If it is a Cobra 4.3 it holds 64 ounces of gear lube.Many water intrusion problems are from the drain,fill and dipstick gaskets not being replaced.
Any Johnson-Evinrude dealer sells them.
You really need the REAL factory manual..
Here is a download for one but the printed version is best.
http://www.mediafire.com/download.php?mzdzzqjmdzd
Here is the original printed manual...expensive but worth every dime!
The seller's name is Don.Tell him Gary in NC sent you and ask if he has any of them that are used and a lower price...
http://cgi.ebay.com/ebaymotors/1988...ure?hash=item2ea8048c7c&_trksid=p4506.c0.m245
If it is good or not is not the issue any more. With warer in the lube. Metal chunks on the magnetic screws, etc...I just want to ensure that the motor is fine. I Intend to have the I/O replaced. I truley believe it is fubar. Thanks for the info.no it definitely is not!
