jbroadhurst1967
- Sep 1, 2009
- 4
I had a local mechanic replace a bad coupler on my 2002 Sea Ray 220 BR this week. The engine was running fine before but since the engine went back in I have no spark from the coil wire. I have swapped the ignition module, coil, and crank position sensor with known good parts and still have no output from the coil. I have 12v on coil and ignition module on the correct wires by the diagrams. All the swapped parts work fine on the other engine. If anyone has any ideas I'm open to anything at this point!
