This spring I replaced the outdrive bellows and gimbal bearing as I noticed a grinding sound when turning and water in the outdrive gear lube. Everything sounded great to start but now I am hearing a clicking noise from the outdrive. I only hear it at lower rpms when turning. Does this mean the u-joints also need to be replaced? I did grease the u-joints before the outdrive was reinstalled. Thanks!
