wonderboy1961
- Apr 20, 2009
- 2
I have a bass boat with a 1978 Evinrude 175 with power tilt and trim.
The TnT has worked intermitently when trailered since I aquired the boat a year ago when, and no problems while in the water. It has now stopped working completely. The batteries are completely charged, and I've replaced the solenoid. I've cleaned all the contacts and replaced any questionable connectors. The solenoid clicks when the switch is in the up position, but nothing in the down position. If I understand what I've read in the older posts in this forum that the solenoid is not used for the down position any way. The Tilt and trim worked one minute and then simply stopped, the hyraulic motor does not function in either up or down position. I'm not sure if I understand how this thing is wired and why the tilt/trim down doesn't use the solenoid, unless it doesn't draw as many amps, and therefore doesn't need the use of a solenoid. I don't consider myself a mental midget, but this is baffling me. I do have the solec manual and have read it inside out and backwards and I'm no closer to solving this problem. Any help would be appreciated
