Please Help...
I was out on the water this weekend ready to do some fishing. The motor seemed a little bit labored when I would give it gas, but nothing too major. After about 10 minutes runing it....BAM, it quit. It was a rapid quit, really sudden and fast. Tried to start again and saw that the starter was not even turning the fly wheel. Oh !@#* I thought the engine was siezed. No smoke or anything outright hot when I felt it. Took it out of the water and dropped lower unit to separate problem areas. After dropping lower unit the flywheel freed up and turned over great. Not a siezed piston or ring, wheeew. BUT the lower end gear will NOT turn or budge a millimeter. I am into fixing these things and got into the lower unit up to the point where the shaft enters underneath the impellar unit. Took four screws out of square bearing housing and seal assy but cannot get the dang thing off.
Am I barking up the right tree, and if so am I going about getting the gears and rods out correctly.
I am missing a flange on my impellar. Could it be jammed in the gear assy?
Thanks,
Tigerone
Thanks,
Tigerone
