I have a 1998 Bayliner with 5.7 Ltr. carb Mercruiser I/O. The starboard exhaust manifold riser is too hot to leave your hand on it. The port riser is warm but not too hot and you can leave your hand on it. I replaced both exhaust manifolds in the past but did not replace the risers but I did check them for obstructions. Not long after, I found the raw water pump impeller was deterioated and replaced the impeller and removed all of the impeller pieces from the thermostat housing. I also replaced the thermostat. When I ran the boat in the water. The water temp. is 175 degrees Farenheight and the engine is running great but again the starboard exhaust manifold riser is too hot to leave your hand on it and the port is warm but you can leave your hand on it. During fresh water flush out at home using the water hose and engine at normal operating temperature the water coming out the port side is cool to the touch but the starboaard side water is very warm but not too hot that it would burn you. Question: Do I have a problem or am I worrying for nothing?
