sonoramike
- Nov 21, 2005
- 32
1990 J60TLESM - took the boat out for the first time in a few months yesterday. As a new owner with little outboard knowledge I've always been impressed by the solid stream the motor put out even at idle. yesterday thought was a different story. Just logged a few minutes searching this site and reading the threads that came off the search while trying to get a handle on what the problem might be, but I've come away with more questions vs answers
is there a source for the actual factory manual for this specific motor vs the piece of garbage SELOC manual (pn (010-1) 1308) that I'm struggling to use? even a pdf would be great to have at this point
symptoms:
weak stream at idle - like a strong fast drip vs a stream. doesn't get much better while underway.
what is the actual purpose of the pisser stream?
should the water coming out be the same temp as the water going thru the water jackets around the cylinders?
what is the diff between the water that comes out from around the prop vs the pisser?
how do you tell if the water pump impeller is shot?
can I blow any obstruction out by shooting compressed air back thru the pisser towards the pump?
water pump is on the top of the lower unit?
Thanks in advance
symptoms:
Thanks in advance
