bryanwess2000
- Jul 16, 2008
- 240
I still have water coming out my upper exhaust( just below the cowling)
after replacing the 2 exhaust cover gaskets. The only thng I didn't do was use the anticorrosion grease since I had some pretty bad areas of corrosion I had to use some gasket sealant/maker to fill in these areas. then I torqued each bolt to 250 in/lbs in sequence x2. The water pressure from the pee line increased dramatically but there is still water coming out the exhaust. Any Ideas what I did wrong or can do to fix this? I'm hoping to gat a few more years out of this motor.
